avidfanjpl
Jul 13 2011, 02:57 PM
I think mine is offset 1 to 1-1/2 inches toward the passenger side.
How do I fix it?
Should I just replace it?
Probably 1 inch is the offset spacing right now.
Could it be broken under the fuel tank?
Thanks!
John
Dave_Darling
Jul 13 2011, 03:23 PM
Do you mean the bar has slid sideways in its bushings? Yeah, they can do that. Just shove it back to the center again. Some will put collars on the bar to keep it from happening again. Some I think use hose clamps for that, even. There shouldn't be a lot of lateral force on the bar, so the clamp shouldn't really hurt anything.
--DD
rjames
Jul 13 2011, 05:32 PM
A hammer and a block of wood between it and end of the bar when you whack it so you aren't hitting metal on metal.
avidfanjpl
Jul 13 2011, 05:56 PM
Thanks, Guys!
It was so far over that it was hitting the shock tower.
Took it up and took the tension off and it moved. It needed a good whack.
John
