Body-
• Media Blasted to bare metal.
• Rust repair was done, new floors, front wheel arches, frame supports
• Roof section was from a 21 window bus, original slider top
• Complete paint and bodywork, Undercoated with Spray bedliner in bed and underbody.
Engine
• Porsche 914 2 liter
• Built to 2365 cc with Scat Pistons and cylinders
• Fat Performance Cam
• Fat Performance 911 Porsche fan conversion
• Fat performance Stainless Steel Valves
• CB performance fuel injection setup
• External oil filter and oil cooler with thermostat fan
• Custom exhaust with 1 5/8" primary and header pipes
• Flow Master cross flow muffler
Transmission
• Type 1 VW swing axle with a Freeway Flyer gear ratio.
Brakes
• Porsche 944 front disc brakes
• So Cal Imports rear disc brake conversion with Porsche 5 on 130 mm bolt pattern
• Duel master cylinder
Wheels
• Factory Porsche Boxter Twist 7 X 17
Suspension
• Dropped and reinforced front spindles setup for disc brakes from Wagons West
• Narrowed front suspension beam set up with inboard airbags
• Modified rear spring plates with Air Ride
• Air Ride air bags with compressor and tank mounted behind rear seat.
Misc.
• Converted to 12 Volt
• Wolfsburg West Front flip out Safari Windows
Interior
• Seat covers came from Sew Fine interiors
Email Me If Interested And For More Pictures
- it's NOT ok to contact this poster with services or other commercial interests
