QUOTE(echocanyons @ Jul 16 2011, 12:26 PM)
I am told that the Boxster non 'S' types clear 15' wheels, but my 'S' type/996 brakes wil not and I needed to use 16" wheels.
Heater guy, could yuo explain a bit more about the details of your setup? I would like to use bigger rotors than the SC rotors I am currently using. Did you space the calipers or the mount what adapters are needed for the rotor to the hub?
I used wanted to use 2 piece directional vane rotors with aluminum hats. Directional vanes cool much better and the aluminum hats are much lighter than cast iron. To have enough space for the hats, I needed to increase the dia. of the discs to 312 mm. I use the 312 mm discs front and rear.
Another advantage of a 2 piece discs is they are less expensive than the one piece. The custom discs and hats were made for me by Coleman Racing Products in Michigan.
I used the adapters from Rebel S and machined spacers to space the caliper for the 312 mm disc. I gave Clint at Rebel the information and perhaps he will make a run of adapters to work with the 312 mm discs.
