QUOTE(MikeSpraggi @ Jul 17 2011, 10:25 PM)
Would they make a difference for a stock /6?
Yes, anything that helps the cooling fan push air from the top is going to help. in fact, they should probably go all the way across rather than simply target the cylinders. But that would take a little wind-tunnel work to check that theory out. They do occasionally get scraped during a curb high-side, but better cooling that doesn't cost you a bunch of horsepower is always a good thing. Keep the flaps!
I'm using the same effect on my front oil cooler outlet.
Click to view attachmentThe only low pressure areas on the car are either at the front (right behind the bumper) and anywhere else where a "thing" sticks up and creates one behind itself.
OT a little:
Now, from a road-holding perspective a partial vacuum under the car would be the best... in the areas we select, of course. That would be everywhere except where air needs to cool, like the transaxle. A good example is the Chaparral Can-Am car from the '60s early '70s.
Click to view attachmentThose guys were seriously after low pressure. It was eventually banned from competition because nobody could keep up with it in the corners and, or so I've heard, it was a little hard on the tracks. I doubt the last one a bit, but if all cars were vacuum cleaners...
http://www.google.com/search?q=Chaparral+C...070&bih=730
