QUOTE(racerbvd @ Jul 18 2011, 12:25 AM)
Yep, painting the case = higher temps, but how about ceramic coatings??
Ceramic coatings work where they work _because_ they are insulators... Piston tops, exhaust systems...
Depends maybe on where you live. Until I moved to the salt/rust belt, I'd have never considered running anything but bare alloy. Here, I'd never consider running bare alloy...
So - GunKote. It's a thermoset paint (although there is a room-temp version too...) Nominal thickness is something like 0.0005" and while that might hold in _some_ heat - it can't be much. Like Jake says, if that little bit is the straw that breaks the camel's back, you have bigger issues.
I've used GunKote "matte stainless" coating on an alloy automatic transmission deep sump and diff cover. If you have 'real' bare alloy to compare it to, you can see the difference, but all by itself, you'd never know. And it will keep the corrosion at bay.
Comes in a lot of colors but black and matte stainless are all I have used.
