I need to replace both inner rockers on both sides. I was going to use the clamshells which normally are applied over the inner rocker and rest of the long instead of the using an inner rocker replacement because I am missing the pillar box areas and figured the added metal on towards the back of the long would be a good thing.
I understand they are the same gauge as replacement inner rockers so that is not an issue. Any concerns with doing this as opposed to just replacing the inner rocker with regular inner rocker?
Thanks
