QUOTE(VOX @ Jul 20 2011, 12:46 PM)
i've actually considered running them through the tunnel, as well as the behind the rocker panels, however i'd prefer to not cut into the center tunnel. also in order to get it behind the rockers, it goes through my wheel well, which i really dont like, as i have 7" wide rims and i dont want them hitting the hose. if i were to go through the center then behind the rockers, that would defeat the purpose as it already hangs low. one option that i did like was the hard lines through the longs, however that seems like a nightmare on its own for doing any repairs. the way i see it, yes it is susceptible to more dmg underneath the car, but repairing it wont be as difficult. and i've already bought the hoses so theres no turning back now haha. however thanks for the information guys.
currently i am leaning towards normal rivets with the conduit hangers, as i dont have much skill in upside down welding. the way i figure it is if i need to remove the hose for any reason, drill out the rivet, and pop new ones back in.
the rivnuts are interesting, but i would need a notching tool, so im thinking either normal rivets or maybe rivnuts.
also the hoses wouldnt even be the lowest point of the car, as the engine bar hangs lower, then the oil pan is a little above that.
Hey VOX,
I hear you on cutting the center tunnel. First, I should share that I'm comfortable do ANYTHING I want to do the the car to achieve my results. I've been racing and working on cars for 40+ years and have a decent shop to support me.
The most important addition to my shop was a wire-feed welder! With that in hand, I can cut and reweld anywhere. So that's me and not most guys.
The concern I have is that UNEXPECTED driveway or pot hot that disembowls your cooling hoses. If you are a VERY AWARE driver then you would notice the sound, followed by the spray of water behind the car. However, I believe you are a ADULT and master of you life and decisions.
So it comes down to "roll the dice" and 99% of the time you will be fine! For my car, since I was planning running it on-track, I kinew there could be the situation where bottom mounted cooling could bite me. For instance, during my last track day 25 June at Streets of Willow, in the afternoon, the track got hot and very greasy. In the top end of the track in 3rd gear, I lost the rear-end. Eventhough I stayed on-track and kept the engine running, I grabbed 1st and DOVE off-track to make sure I would be T-Boned! Once off-track, I was surprised how nasty & bumpy the desert was. However, NO Worries: I just had to keep the tires from being punctured.
At the end of the day, I want to best for your project and the MOST fun with it without problems.
BTW: There is another benefit to opening up the center tunnel: cleaning up 30+
years of grim and rust! Once inside: It was Scary!!
Best,
Terry
