QUOTE(kkid @ Jul 20 2011, 09:00 PM)
1: 10mm nuts on the T/O bearing guide tube
2: 14mm Pivot Ball(has 2 shims)
Hints on fastener sizing and torque ratings.
Fasteners are sized by their threaded portion - not their head size.
a 10mm fastener is huge - like your cylinder studs, The guide tube fasteners are 6mm (M6) which as a rule-of-thumb takes 7 lbs-ft. (Yes, it is 10mm ATF - makes no difference...)
Similarly, the ball stud is not 14mm. IIRC it is 8mm and is looking for something in the neighborhood of 13 lbs-ft. Since it's a PITA to get at, I'd probably clean everything really well and use Blue (i.e. mild) threadlocker.
But I couldn't find that spec'd either, and I can't go looking in the factory repair manual this morning.
