QUOTE(rick 918-S @ Jul 20 2011, 10:52 PM)
Thanks!
I have all the pieces you need, just pay shipping.
What I dont have is the brackets on the motor (and you buy new rubbers)
I can send you a straight bar with the little brackets on the end if you need.
If you make the little brackets (u-channel) make all the holes oval...so you can move it around a bit....I would say twice the length is enough.
You can, and I have, mount this motor out of square.
Measure to the firewall from the motor...the rubbers will cooperate.
If its out of sqaure, its harder to get the shifter perfect.
I also replaced the firewall bushing with a custom one made from tephlon impregnated bronze.
Huge flange, bolted to the firewall (that sucked) and much tighter tolerance on the shifter bar.
Round out both inner edges of the flange....
The shifter bar pivots on that bushing, so the tigher the tolerances, the better time you have shifting.
Not super hard to make, just need to get you mind around what that shifter bar is doing.
Rich
