bobhasissues
Jul 22 2011, 01:34 PM
Someone recently (about a month ago) posted looking for proper ring gaps using 96mm AA cylinders with Keith Black pistons. I want to verify that same info but cannot find the post. Anyone have the link or specs?
tomeric914
Jul 22 2011, 03:17 PM
It may vary by ring manufacturer. I used Hastings rings and followed their specs.
SLITS
Jul 22 2011, 06:05 PM
From the Workshop Manual on a 1.7L (92 mm bore) engine, assuming stock rings & pistons:
Top ..... 0.0138" - 0.0217"
2nd ..... 0.0118" - 0.0217"
Oil ...... 0.0098" - 0.-0157"
Since your bore diameter larger, I would use the higher figure as a starting point.
Best I can do for you.
