The sale will be held at: 401 Rt 35 Red Bank NJ 07701. (look for the white sign with red lettering that reads "landscaping equipment sale")
All parts are in great like new condition.
I have no pictures so please do not email me asking for pictures, and I will not be available today to show anyone the parts stash before the sale.
Prices are fair and firm.
The list is laid out as follows:
Item #... Part Description... Quantity... Price
1 Transmission 3 $400
2 Targa Tops 4 $75
3 Front Bumper 1 $250
4 Rear Bumper 1 $250
5 Rear Hood 1 $300
6 Alloy Wheels 4 $125
7 Alternators 2 $50
8 Front Fender 2 $75
9 Passanger Door 1 $200
10 Left Rear Quarterpanel 1 $125
11 Wiper Motor Assembly 2 $75
12 Headlight Motor 6 $50
13 Front-End Assembly 1 $500
14 Front Valance Pan 2 $50
15 Rear Valance Pan 2 $40
16 Regulator Plate 4 $45
17 Starter Motor 3 $75
18 Steering Rack 1 $200
19 Inner Door Panel 2 $40
20 Steering Wheel 2 $50
21 Door Handles - Outer 2 $40
22 Steering Column - w/Key 1 $75
23 Voltage Regulator 3 $15
24 Armrest Plastic Tray 2 $25
25 Armrest Cover - Drivers Side 2 $20
26 Instrument Gauge Panel Holder 1 $15
27 Pedal Assembly 1 $100
28 Fog Light Lamps 1 $60
29 Headlight Relays 0 $15
30 Fuel Tank Sending Unit 4 $50
31 Side View Mirrors 2 $125
32 Plastic Headlight Covers 3 $15
33 Fuel Tank Overflow 2 $20
34 Brake Fluid Resevouir w/Cap 1 $20
35 Rear Interior Back Bulkhead 2 $75
36 Sunvisors 6 $30
37 Front Bumber Strip 1 $175
38 Headlight Switch 4 $50
39 Fog Light Switch 3 $15
40 Hazzard Flasher Switch 3 $35
41 Drivers Door Pocket - Arm Rests 2 $25
42 Steering Wheel Horn Pad 2 $40
43 Interior Rollbar Trim 2 $10
44 Front Hood Latch - Lock/Catch 3 $20
45 Tachometer 3 $50
46 Bumper Support -> Dog-Bone Mounts 6 $20
47 Middle Seat Cushion 2 $25
48 Door Stops 4 $50
49 Lower Dashboard Panels 4 $45
50 Fuse Box Panel 2 $25
51 Headlight Motor Covers 4 $15
52 Spare Tire Trunk Board 2 $25
53 Turn Signal Relay 2 $20
54 Ash Tray 1 $25
54 Ash Tray 1 $25
55 Headlight Cover Trim 4 $15
56 Front Hood Latch - Upper 2 $25
57 Rear Trunk Latch - Lower 2 $15
58 Gear Shifter 2 $15
59 Expansion Tank 2 $55
60 Rear Liscense Plate Lite 2 $15
61 Engine Cover Latch 1 $25
62 Foot Well -> Right Side 3 $15
63 Rear View Mirror 2 $100
64 Engine Lid Drip Pan 2 $50
65 Front Hood Hinges 4 $10
66 Non-Fog Light Grilles 1 $5
67 Interior Light Assembly -> Clear 3 $10
68 Engine Mount Bar 1 $50
69 Rear Glass - Heated 1 $50
70 Rear Glass - Plain 1 $30
71 Sun Visor Brackets 2 $20
72 Turn Signal Indicator/Switch 1 $50
73 Speedometer 2 $70
74 Fuel Gauge 2 $30
75 Rear Hood Hinges 4 $15
76 Oil Cap 1 $8
77 Inner Door Latches 2 $15
78 Emergency Brake Handle 1 $25
79 Rear Trunk Cups 2 $10
80 Ignition Coil 1 $10
81 Rear Trunk Lock - w/o key 2 $35
82 Engine Lid Grill -> Both Sides 2 $15
83 Engine Lid grill -> Main 3 $25
84 Seat -> No Bottom 1 $95
85 Seat -> Bottom 3 $25
86 Rubber Shock Caps -> Rear 5 $5
87 Window Cranks 2 $10
88 Flasher Relay 2 $30
89 Headlight Relay -> High/Low Beam 2 $20
90 Door Vent Window 3 $15
91 Door Window 2 $50
92 Front Parking Light Assembly w/o Lens 2 $25
93 Black Plastic Wheel Caps -> Set of 4 4 $5
94 Front Bumper Guards 4 $35
95 Heat Control Lever w/Red Knob 1 $17
96 Side Marker Lights -> w/o Lens 2 $10
97 Targa Top -> Plastic Holding Clips - Rear Trunk 3 $10
98 Wiper Arms -> no blades 2 $20
99 Targa Roof Latch in Roll Bar 2 $20
100 Inner Door Handle Cover Plates - BlackPlastic 2 $5
101 Engine Lid Lock 1 $10
102 Door Butt Stricker 1 $10
103 Gas Cap 4 $10
104 Defrost/Air Vent Console Controls 1 $25
106 Interior Door Handle Armrest -> Passenger Side 2 $30
107 Windschield Pillar Post Interior Trim 2 $30
108 Targa Top Rear Clip 2 $10
109 Right Rear Tail Light Assembly - w/o Lens 1 $65
110 Horns 3 $10
111 Cover Tray Under Steering Rack 1 $25
112 Headlight Eyebrows 4 $10
113 Front Trunk Latch 1 $10
114 Headlight Carrier 6 $25
115 Rear Trunk Light 2 $15
116 Front hood Lock Cable w/o Key 1 $50
117 Center Console Base Plate 1 $30
118 Glovebox Door 1 $25
119 Adjustable Seat Track 1 $20
Come and see what you might need for your 914!
- it's NOT ok to contact this poster with services or other commercial interests
