QUOTE(SirAndy @ Jul 22 2011, 08:04 PM)
It's the backing plate with the hose adapter that seems a wee bit overpriced ...
Those duct plates are more difficult to make than it appears.
Fitment of the inlet tube around the strut is critical, as there is only one spot/angle where it will fit when installed. Also it needs to have a special shape where it attaches to the disk because part of the inlet tube sits outside the od of the disk.
I made my own, but they would be more expensive to reproduce, not cheaper.
I made the disks fit more tightly to reduce the amount of air bypassing the rotor vents.
I designed the inlet shape to maximize air flow into the rotor.
Rather than attach the inner cover to the wheel hub, I attached it along with the outer cover to the backing plate mounting holes, and used standoffs to give them the appropriate gap to match the rotor.
I also added a bracket and attached the outer cover to the strut with a hose clamp to make sure it doesn't vibrate/rub.
When the steering wheel is turned the hose attached to the backing plate pulls on the assembly, causing it to flex.
Click to view attachmentClick to view attachment
