Broke an exhaust valve spring on my newish (2000 miles on it, but 4 years old) motor Wed. Just did a compression check and pulled off the exhaust for #4 cylinder tonight.
Good news is I shut down quick but not before the valve spring washer had been pummeled, but I have spares. Piston, bore and valve look good fortunetly.
The trick will be getting the valve spring compressed enough to get the keepers back in while it's still in the car.
Anyone ever done this, have some suggestions?
It's sort of weird, the spring seems to have broken into three pieces. Thinking I shouldn't have used new stock springs now. The 2.2L engine has a light weight flywheel, the top end has been flow benched and the compression raised. So it rev's like mad and it's a ton of fun between 3000K and 6500K. If I keep the motor I'll probably invest in a set of performance springs.
