Bill, the arm mechanism, the latches on both the door and door jam are a Clear Zinc. They look silvery. The unit with the rubber boot that screws into the door jam I seen 3 different ways.. can't verify if each part was "Factory" correct. The ones that are still availble are that dark yellowish zinc color. My 73 had black plastic with a different type of wiring set up. My current 74 has them in a clear zinc. The screws on the 74 are a dark yellowish zinc. Here's a link you can poke around in of the past cars. Should show the door jams in detail.
http://s283.photobucket.com/albums/kk296/t...;cpZZ3QQtppZZ16There's quite a few albulms.. the red car has a close up of that, and so does the white one.
