QUOTE(streetrover @ Jul 24 2011, 07:55 AM)
I installed a new Master Cylinder yesterday. Adjusted the rear calipers and bled all the lines. Rears work great but fronts don't squeeze? Any thoughts?
Thanx,
Bob
1. Try to bleed the front calipers.
- If they bleed, rebuild the calipers.
- If you see no fluid coming out when you press the pedal it means the MC doesn't create pressure in the front circuit. Continue to step 2.
2. Crack the front lines connection to the MC and press the pedal.
- If it bleeds, your lines are blocked.
- if not, the MC is RIP or something is connected wrong.
Let us know where you get with this and will pick-up from there.
