QUOTE(jgiroux67 @ Jun 28 2004, 03:03 PM)
QUOTE(Dave Avery @ Jun 28 2004, 10:05 AM)
Looking for 911 rear 8's , not 951 8's (front of a 911).
What is the difference and what is better to use on a flared 914?
The part number of the 8" x 16" Fuchs wheels that came on a 944 started with 951. The part number of the 8" x 16" Fuchs wheels that came on a 911 started with 911 (duh!). The offset of the 951 and 911 8" rims is different. 951's have a 23.3mm offset and 911's a 10.6mm offset, i.e., the 911 wheel would stand further from the chassis.
Personally I like more the look of the 911 wheel since the center sits deeper in the rim. For usage with flares I'd think a 911 wheel would be better since it would require less spacer in the front to fill out the flare. I have 7.5" x 17" rims with 23mm offset for the front and will need a substantial spacer. In the rear you probably don't need a spacer with 911 wheels if you put a 245 series tire on.
Drawback is that 911 8" wheels are more expensive than 951's.
