scottb
Apr 22 2003, 06:15 PM
i know i asked this before but only now do i have the beast on jack stands.
my speedo will work fine up to about 30-40 mph then start flying around from 40-120mph.
how does one diagnose the source of the problem? speedo cable or angle drive?
or should i just throw $ at it until the problem stops or a new more expensive problem shows up?
thanks...
J'aime les français, ils font de vraiment bonnes pomme de terre et les bonnes pâtisseries.
scottb
Apr 22 2003, 06:53 PM
never mind, found my old post....
thanks...
Bleyseng
Try another speedo to see if that works first.
If it does the same thing its probably the cable that has a kink in it.
The angle drive doesn't go bad unless you jack on it. They just leak oil.
Geoff
krk
Apr 22 2003, 06:55 PM
Geoff's right. Bouncing is usually a bind the cable. Loading/Unloading causes the bounce.
kim.
