9nine
Jul 25 2011, 01:58 PM
my 1974 914 wont go, unless it revves up to 3000rpms??? if it gets to the higher gears it will go, but when I slow down for a stop sign it wont go, even with the pedal to the floor, 74 914 1.8 fuel injected manual. any ideas please help..it's my only car and now I can't drive
jsayre914
Jul 25 2011, 02:08 PM
More deatails please..
Is it stalling?
Can it idle?
How long has it been running like this?
rnellums
Jul 25 2011, 02:09 PM
if your linkage slipped then you could be shifting into the higher gears. When you think you are going into first, you are actually hitting third?
benalishhero
Jul 25 2011, 02:12 PM
Slipping clutch?
VaccaRabite
Jul 25 2011, 02:24 PM
I am guessing that you need a new clutch ASAP. The job is not hard. At least not as hard as it could be.
Zach
rnellums
Jul 25 2011, 02:34 PM
wouldn't the clutch still slip at higher gears too though? I know it would slip for less time though.
9nine, does the engine die before the car starts moving in lower gears?
tradisrad
Jul 25 2011, 02:59 PM
i had the main shaft in my trans break and I was unable to use first gear, however I could put it in 2nd and get moving
Rand
Jul 25 2011, 03:01 PM
All we can do is guess at things until you give us more info.
Does the engine rev or bog?
rnellums
Jul 25 2011, 03:03 PM
QUOTE(tradisrad @ Jul 25 2011, 12:59 PM)
Yikes!! How did that happen???
SLITS
Jul 25 2011, 05:24 PM
Set the E-Brake (if it holds), start the car, hit the gas as normal, select 4th gear, let the clutch out, if the engine doesn't die your clutch is GONE.
