QUOTE(pcar916 @ Jul 25 2011, 01:55 PM)
I just went through this last week to install a Lexan rear window and it was harder than it should have been. There were three screws that were nearly impossible to find because a PO had put in additional screws on top of them... so I only thought I removed them. Use a really good phillips-head screwdriver. If the heads get stripped they're not fun to get to. Also, before you re-attach the pad make sure you peen the screw holes so they still hold with the standard screws. You don't want to find out you'll have to use oversized ones while you're installing it.
Honestly, I don't know what the person responsible was thinking. He also left off the clips that hold on the hooks so that the pad was retaining it. Naturally they fell apart when I got the pad off.
Just keep on looking for screws you've missed. It pulls off just fine unless someone used silicon along the top edge of the rear glass and accidentally "glued" the rear of the pad to the glass.
Good luck
I am thinking it might have been glued, either on purpose or accident. the window does have quite a bit of whatever goop was used to seal it squeezing out at the bottom so i can imagine the top side is not much better.most of the screws on the bottom side were already missing, i can look up in the holes and see they are not there. Feels like it is most stuck in the center on the underside near the window and i can't imagine what else could be holding it.
I have made attempts already on 3 different days to get this thing off, i think the next attempt might end with
I hate to destroy it but think i have a spare somewhere
