QUOTE(SirAndy @ Jul 25 2011, 10:38 PM)
QUOTE(john rogers @ Jul 25 2011, 09:13 PM)
while I moved the shift handle into the 2nd gear position and locked the clamping bolt. I also adjusted the stop bolt for the 2nd gear position at the same time.
The stop bolts need to be all the way out while you do the adjusting, otherwise they can interfere with the adjustment. Once everything shifts as desired, you screw the stops back in until they just barely touch and then lock them in place.
I always found that putting the trans in 2nd before doing any adjustments on the lever works just fine if you are by yourself.
That way, you know exactly where you want your shift lever to be (center and forward) and everything else basically falls into place from there ...
I put the car into second back at the transmission and then slid the (not tightened) coupler on to the shaft. I made sure it was centered side to side then moved the shifter forward until it stopped, i.e., the inside of the shaft was bottoming out in the coupler. I tightened the coupler. Then tried selecting all the gears and everything worked.
I would have thought I had to slightly back off bottoming out the shaft in the coupler, you know like more "centered". This bothers me.
Anyway I then drove (nervously) down the street and got a bit of grinding when shifting to second and third. Actually this could be happening at events, but you don't hear or feel it.
I'm am going to tighten my clutch cable a bit and see if that helps. My syncros are all good or at least they were when we put in the TBD, about 20 minutes of hard racing ago.
