FS: 1976 Flared Roller SOLD
Flares are F/G with no Cracking. I owned this car briefly in 03 & the flares look the same now as they did then.
Car has not been driven since 02 when a 3.6 was taken out for another car.
It has Carrera Front Calipers, M Rears. 16" Real Fuchs with new tires on the fronts ( Rear tires are good to roll around, I wouldn't drive on them), Comes with 901 Sideshifter, Gas Tank, Seats, All Glass, GT Style Engine Lid, Front F/G Bumper, I think I have a Rear Metal, Bumper front GT Valance needs some work. Flared rockers are weird but could be saved - someone modified them with a Metal section in the middle that is rusted. Longs are perfect, there is a small rust hole under the battery but not in the usual spot, so it is OK. There is a little Surface rust from scratchs that I have ground down & hit with Primer. There is a Rust hole at the bottom of the passenger down that can be patched and there is a hole in the floor pan on the passenger side under the seat about the size of a Silver Dollar than can be patched
Still has the 4 Cylinder Mounts, does not have any Bulkhead -6 Mount as this car had at one time a Patrick Bar. No Oil Tank
