QUOTE(SGB @ Jul 27 2011, 11:13 AM)
Does that hood ornament in yer avatare come w/ the car? Not OEM, but looks great. You won't get a pic like that with a Civic.
Accel cable:
Yep, the clutch cable and accel cable interfere w/ each other on my car too. IIRC, the pivot arm kinda bends inward over time and use until the accel cable sorta drapes over the clutch pivot. I hope I remember this right...
I think you just need to bend that arm that the accel cable connects to toward the pasenger floorboard area- center of car until the cables don't touch...
What kind of dizzy are you using? Is it in correctly? The car will run with diz 180 out if plug wires accomidate, but a bosch 009 (maybe an 050 too) retard #4 a tiny bit I have been told.
Are you sure the intake valve is correctly adjusted on the dead cylinder?
Good luck. It will probably turn out to be something really simple.
I have had the car for 2 yrs, tagged and insured, but re-occuring miss just takes all the fun out of owning the car, bet I have not been able to put 10 miles on the car sense driving it home from FL seller. 009 dis, fires up well no matter how long it sits[except for this one cyl] Driving me to sell!!! Hood thing stays with me Bob
