yeahmag
Jul 27 2011, 10:28 PM
I need the following two crush washers post haste!
N-013-845-2
N-013-829-3
These are the crush washers for both pressure relief pistons on a '74 case. I'll check with Porsche in the morning, but if someone has them and wants to drop them in the mail I'd gladly buy them from you!
Thanks.
-Aaron
detoxcowboy
Jul 27 2011, 10:32 PM
yeahmag
Jul 27 2011, 10:41 PM
Looks like they have one, but not the other. They are listed as:
Oil pressure relief valve crush washer - N 013 829 3 - aluminum, 22mm
Oil pressure control valve crush washer - N 013 845 2 - copper, 16mm
tradisrad
Jul 28 2011, 07:25 AM
try high performance house @ 650-364-6234.
I found a 12mm crush washer for my tuna can at Napa Auto parts last saturday (HPH was closed); they may have the larger ones also.
yeahmag
Jul 28 2011, 11:58 AM
I just ended up ordering them from Pelican Parts. Thanks.
yeahmag
Aug 1 2011, 06:11 PM
Turns out Pelican can't get the crush washer for the relief valve below the push rod tubes:
N-013-845-2
Bump again in case anyone has one floating around. I left a message at HPH too.
-Aaron
