As I recall, like many Porsche projects I said to myself "how can this be that difficult". I drilled the holes, purchased a stainless steel bolt, washer, lock washer and nyloc nut. Take your spare tire out and climb in there in the front compartment. You will now see a small opening right where the front bumper 5mph shocks attached and underneath the front lights. You have a very small space that you can access the back side of the front chassis panel. I got good light in there and took my time, I held the bolt and foglight in place with my right hand/arm and I used a combination of tape, hemostats and my skinny fingers on an open ended wrench in the 1 to 2 inch rectangular opening. This would have been easier with a helper to hold the bolt and foglight in position.
I just looked at it to remind me how I did it and after you look at the opening it is not that difficult. Like any other thing on a German car you have to make a tool or really think through the process.
I have to say when I finished this and realized how solid the result, I was happy.
When I cut off the lip on the front and the small tab on the back, I have a hand grinder Makita, that can turn some serious RPMs, I put the cutting wheel that and held on tight and Carefully cut and then I bent the extra down, when I was done it looked correct then I sanded and primed and painted all the cut surfaces, it was not as difficult as it appears. If you had a pneumatic cutting blade that would be ideal.
The pilots were sprayed with that Japanese Tuner paint from Van's, it was very pricey, but I like that the color is different, and it is specifically made for lights.
Being as your Pilots are brand new just clean the lenses surface and then put a series of light coats on, I did them over several days and they really took well. I also used the vans on my Foglights on my 911SC Weissach and had enough left for my buddy's 69 911T. Very happy with the color, found the Van's paint on E-Bay.
After looking at the pictures I also cut out two pieces of metal the shape of the piece that held the 5mph bumper in place and drilled holes in them primed and painted them and put them back in to cover up the hole where the bumper came through.
Vysoc
