QUOTE(Razorbobsr @ Aug 4 2011, 09:20 AM)
I have a HP 2L carb 44 IDF 914 that runs great above 3K, Porsche mach of some 30 yrs says I have a very solid rebuilt engine with a hotter then stock cam, the exhaust sys in too big past the collecter but header is a damn fine unit. He also says the exhaust sys has nearly no back pressure and wants to size it down from 2inch to 1 5/8 or 1 3/4, and I need to dump the TOO damn loud cherry bomb muffler. The porsche guy builds racing engines for the local Indy market, has his own dyno and flow bench, grinds his own cams, and seems to know his stuff as he only works on Porsche's. After talking to him yesterday, he thinks I also need a hotter/better eng sys, like a MSD, rather then stock 009 sys. Gents........... Your thoughts??? Questions?? Bob
Porsche guy from Indy called to let me know I could have the car back, good news! Bad news?? After playing with the engine for several hrs[$$$$] and re-jetting carbs, he has concluded that the PO had some serious cam in the car, pulls hardest above 3500 rpms, willingly revs above 6500, idles at about 1100 to 1300. Now he tells that its almost as smooth as an injected 2L[Almost] He seens to be pretty anal about things[and I mean that in the best way!] He replaced the cherry bomb muffler with something smaller that 2 inch[in] and 2 inch[out] and I think he said 1 5/8 ?? He says these engines must have back pressure to run correctly[Right?] And a 1 5/8 exhaust tip, welded the bolts to the header to ease placement, installed a second hanger for the system, he also says moving the car from the FL coast to Indy area may have played a part in the jetting[??] probs. Also installed MSD unit, he says it made a BIG difference in how the car ran, and made it easer to keep plugs cleaned off? Ok gents, and I getting hose and smoked?? Thanks, Bob
