Full Version: 911/914 A-arms difference
datapace
Hi,
I getting ready to start a 5-lug conversion on my 914 and had a quick question about the differences between 911 and 914 A-arms.
One of the a-arms I have on my '85 Carrera suspsension looks like it was used to jack the car up and the area near the rear bearing is bent over slightly. Can I just pull the torsion bars out and use the 911 cross member and front mounts on the car with the old 914 arms and Carrera parts? I know the 914 arms have tabs for a through the body sway bar but are the arms interchangable or are there other differences?
Thanks,
datapace
MXMARK
Different number of splins in the 911 for the t-bar then the 914. Which year 914 because the ball joints are different on different years. Mark
datapace
It's a 1974 914. I plan to use the front and rear torsion bar carriers from the 911 suspension. Will probably replace the ball joints anyway before I install the suspension.
davep
QUOTE(datapace @ Jul 3 2004, 02:48 PM)
I'm not sure what you are saying here. The 914 and 911 rear suspensions are so different that nothing is interchangeable. The 911 rear is torsion bar sprung, and the 914 has coil springs.
You cannot mix parts on the front, with the exception of the cross bar so far as I know. The torsion bars are matched to the A-arms and the adjuster caps. The torsion bars are different rates between 911 and 914. Until you can find a replacement A-arm, just use the 914 front suspension with the 911 struts.
Ball joints must match the strut. Upgrade the 911 A-arms to use the 914 sway bars.
Qarl
What Dave P said.
datapace
I was talking about the rear cap for the torsion bar that fits into the cross member and the front a-arm mounts.
Basically what I am trying to do is to take the complete 911 front suspension and use JUST the 914 a-arms. Torsion bars and adjusters will be 911 going through the 914 arms only.
Thanks,
-bryan
Qarl
Won't work.
The A-Arms have a spline receptical deep inside inside (opposite side from the rear torsion adjuster caps). This spline pattern is different then the 914 pattern.
So basically 911 torsion bars will not fit into 914 a-arms.
The only way this might work is to use the entire 914 a-arm (arms, torsion bar, adjuster cap, and adjuster screw).
datapace
Cool, thanks Karl, I'll locate another undamaged 911 a-arm.
redshift
911 arms were installed on God's gift_to_God's gift to women. cool_shades.gif
911 arms cannot be mounted to the rear axle of a Ford Escort. (euro only) sawzall-smiley.gif
911 arms don't wave about wildly, when stranded on a deserted island, and a helicopter flys over. confused24.gif
911 arms don't grow on 911 trees, contrary to popular 911 lore. chatsmiley.gif
911 arms should not be used as floatation devices, but can if you are also floating on Marlon Brando. pissoff.gif
911 arms throw a mean fastball.... NOT! :finger2:
Your mother won't hit you for sticking your 911 arms out of the window, while the car is in motion. wacko.gif
You'd have to be a 2' 9" ape, if you wanted to drag your knuckles, and had 911 arms. uhoh.. here Pammy.. monkeydance.gif
911 arms were discovered by a famous movie star, Manny Chevetts, who was also a known 'drinker'. monkeydance.gif
There is a place where they send 911s that have lost their arms, and teach them to slide into the turns. happy11.gif
9+1+1=11. If you divide 9 by 11, you get 0.81818181 infinity.. Infinity.. like the chubby you get when you rub your nether regions on a 911 arm. huh.gif
M
Aaron Cox
OMG
miles forgot his dose today, 'nurse, up his dosage to 900mg prozac'
jester.gif wacko.gif blink.gif clown.gif tunez.gif smoke.gif drunk.gif wolfgang.gif
redshift
I take no meds!
M
