But it was idling at 3000rpm.
After an hour, I had the idle down to 1800 rpm. Both idle adjusters were off the stops. Using a snail, one side was drawing a 7, the other a 14. When I turned off the car, I got a backfire. My "work hour" was done, so I had to leave it at that until the next time I can work - probably next Friday.
So causes for the big idle that I need to investigate:
- air leaks at base gasket between carb and manifold (reused, very possible)
- air leaks at top between carb and air filter housing (do they even leak here?)
- bent butterfly shaft (hope not, and don't think so)
- slave cable from weak side to strong side needs to be loosened as it is possibly holding throttle open slightly?
- exhaust leak? Fresh installed SSIs, I probably have one at the head somewhere.
- big carb imbalance? Probably combined with the leak...
Where can I get the good base gaskets? The ones I have are from Weber Carbs Direct and they are the ultra crappy tan cardboard. They took a set and I am sure they are leaking like a sieve.
Zach
