qa1142
Jul 3 2004, 06:19 PM
Anyone have a Pertronics? Are they worth the investment?
Thanks
Will
Trekkor
Jul 3 2004, 06:41 PM
I put in a module on my car a couple of months ago.
They are " set and forget ".
Great at all RPM ranges.
No " point float ". Eliminates tune-up's.
What more can I say? It's an easy install that works, car's never run better. Easier starting.
Some people don't like them. I don't know why?
Jul 3 2004, 07:01 PM
QUOTE(trekkor @ Jul 3 2004, 05:41 PM)
cause they can *burn* out without completely failing and you serach for weeks trying to find the cause ...
Andy
Joe Ricard
Jul 3 2004, 07:48 PM
If'n you run one it is always a good idea to stash the points in the glove box.
Bruce Allert
Jul 3 2004, 08:03 PM
LUV mine
.....b
Joe Bob
Jul 3 2004, 08:30 PM
Carry a set of points for when they fail....not IF.....
fiid
Jul 3 2004, 08:39 PM
I've had pertonics in my car since just after I bought the thing a year ago. It has not caused any problems - although I have heard that is can cause arcing at the plugs. :-)
Chris H.
Jul 3 2004, 08:42 PM
Smoothed out my low end and idle big time.
GWN7
Jul 3 2004, 10:04 PM
So what's better? If pertonics are choice 1 to replace the points what is better?
anthony
Jul 3 2004, 11:06 PM
I've had no problem with my Pertronix. It made my jumpy timing mark rock steady. I've heard you can burn up a Pertronix by leaving the key in the on position too long so I avoid that.
Trekkor
Jul 3 2004, 11:12 PM
So...Here's the deal. They are great until they break.
But, what else is new. EVERYTHING breaks.
Carry a spare motor...I do.
anthony
Jul 3 2004, 11:48 PM
Yeah but they seem to break more often than other products like the Crane or Compufire. If mine goes caput I'll probably get the Compufire.
Air_Cooled_Nut
Jul 4 2004, 12:21 AM
Had the Compufire for over 5 years, no problems whatsoever. Had Pertronix for 3-4 years, no problems. My VW now has the Compufire distributorless system and I LOVE IT!
wheelo
Jul 4 2004, 01:29 AM
Pertronix was a "no-brainer" upgrade, more efficient and smoother, than mechanical points. Just stash points and cond. in glovebox,
(just in-case) Saves on towing !
