I installed a set of stainless lines from the tank for my /4 but decided to go with a /6 conversion with webers. How do you run the return back to the tank or should I at all? Is it as simple as plumbing to the first carb, then to the second and adding a different banjo fitting on the second carb then back down to the return line? Is one of these methods or another prefered?
Kev
