QUOTE(Lawrence @ Jul 4 2004, 08:47 PM)
Do you twist the safety wire by hand, or do you have a tool to do that?
standard safety-wire pliers. they come in at least two sizes; i have the full-size pliers but there are places where the shorter ones would be a help (access issues...) they're not expensive, and all the race places (Summit, Pegasus,
RacerPartsWholesale.com ....) have them.
the pliers have a spring-loaded clip to keep them closed, and a spiral rod you pull to make them twirl around. they're supposed to have a spring return on that spiral but mine broke years ago. they're about $30/
i've been having a hard time finding wire, actually, there is a proper very soft stainless steel wire for this purpose, and i did finally get a spool at Summit. for our purposes, the 0.032" is a good all-around size but 0.025" is nice to have for light applications.
Carrol Smith's "Prepare To Win" shows most of the standard twisting patterns and techniques, and IIRC there's a pamphlet with the tool too. i'll get a photograph of my axle flanges when i get a chance ... for this application, i like to wire paired bolts. run the wire so that it tends to tighten both bolts.
it takes some practive to know how far away from the first fastener to grab the wires so that when it's twisted, it winds up exactly at the second fastener. i figure about a third of the distance is reduced by the twist.
