So these S-pipes and bottom cover was originally on my 1.7 tailshifter.
But I have since switched to side shift config and also swapped the fan housing from I think 1.8L. Are they all the same ?
Apparently I am have a heck of time installing the driver's side s-pipe to the fan housing. It seems like the ears on the driver's side fan housing is sticking up too high to tighten the clamp down. oh yeah my original fan housing the PO had to grind off the ears (for the flap) to install the s-pipe you see. Do I have the wrong set of s-pipe ? I have not tried the passenger side yet. Will that side be ok with what I have ?
Here are some of the pics. Please let me know if they are correct for side shifter 1.7 ??
Thanks guys !!!
