I accept Paypal and prefer it.
Will combine shipping when needed. If you would like to make an offer on a package deal or just single listings, send a PM. I will consider all reasonable offers.
Pictures here (ask for specific pictures and I'll add them):
http://www.flickr.com/photos/58832619@N04/...57627280877435/
two 16x6 and two 16x7 Boxster wheels
-EXCELLENT condition. These fit my 914 with no spacers, your experience may differ depending on tire size.
-Old tires included, A LOT of tread, but can't recommend for long use. Was only planning on using for short term use, DOT date 2002.
-Tires are 205/55/16 and 225/50/16
-16x6 ET50 996.362.112.00
-16x7 ET40 996.362.114.00
L/R 911 3.5" Caliper spacing BOGE struts
-Great condition. I was told that the inserts might need to be replaced, but I haven't tried them out.
-911.341.041.03
-911.341.042.03
two inner front bearings (SKF), two outer bearings (FAG), two seals (Elring Klinger)
-All brand new in box
x20 Aftermarket Alloy Lug nuts (Ralph Boothe) Satin finished - SOLD
Brakes
Used ATE 23mm Master Cylinder
Used Boxster Calipers, Fronts and Rears
-Comes with used pads/hardware, condition looks good but unknown
-986.351.421/422 (F)
-996.352.421/422 ®
Brand new 3.5" front to boxster caliper adapters
and brand new stock 914 to boxster caliper adapters
-Brand new from a914guy (Rich)
-Bolts still wrapped up
$400
Calipers + Adapters: $950
*Following rotors are to be used with boxster calipers
two Rear Rotors, 70-83 911 vented, 20mm wide
