jporsche914
Jul 5 2004, 05:21 PM
I am getting my 1.7L engine rebuilt back to stock specs and i was wondering what would be the best way to break it in. Should i run the engine hard to seat the rings or should i just take it easy and have the rings seat over time??
thanks
Rog914
Jul 5 2004, 05:32 PM
Break in secretsLook through ALL of this website. It will give you a good idea of what to do.
Ralph Gosnell
74 2.0
redshift
Jul 5 2004, 05:34 PM
Run it to 23 grand, I think that is what Bruce Allert told me.
heh
jporsche914
Jul 5 2004, 05:59 PM
I have looked through that website a couple times. It makes sence and it seems like it is a good idea i just want to know what other people think about his break in method before i do it and maybe mess up my new motor.
Jul 5 2004, 06:27 PM
QUOTE(jporsche914 @ Jul 5 2004, 04:59 PM)
i say, you try it and let us know how it goes!
it's too late for me, i already got 50 miles on mine ...
Andy
seanery
Jul 5 2004, 06:29 PM
I've always been told to break it in, like you'll use it. There is a story about a 356 that was a race car in the 60s in Excellence this month. There is a little story about the original owner who asked the factory how to break it in. The story said "Put your foot down"
I like that answer.
newdeal2
Jul 5 2004, 07:00 PM
That's pretty much the same as the site suggests...it makes sense. I am going to try it myself...just hope I don't get caught in traffic
jporsche914
Jul 5 2004, 07:15 PM
That sounds like a great idea to drive it the way i usually drive it, because if i had to be easy on my 1.7L i wouldn't get anywhere (to slow). What oil do you think i should use?
newdeal2
Jul 5 2004, 07:21 PM
Gastrol GTX...it's the bomb
jporsche914
Jul 5 2004, 07:25 PM
Thats what was in it before the rebuild. I like the castrol GTX alot. Would a 10w30 be a good weight to break it in with.
newdeal2
Jul 5 2004, 07:55 PM
Not sure it matters for the first few. I use a 20/50 but I'm in a hot enviroment. Making sure the engine is built with good assembly lube is important.
Also crank the engine with the coil wire off first to make sure you have oil pressure
72914S
Jul 5 2004, 08:12 PM
After the first 100 miles with 30 wt. detergent oil ,I drained it put in 20/50 castrol,new filter,checked the screen for things that shouldn`t be there,recheck valve adjustment......THEN Drove it like I stole it ! Well not quite but I`ve always been told to drive it like you will normally. Now has about 500 miles on it and running great.
Jul 5 2004, 08:15 PM
QUOTE(newdeal2 @ Jul 5 2004, 06:55 PM)
also, you want to fill the oil-filter with oil before you put it on!
just in case you didn't know.
Andy
