QUOTE(East coaster @ Jul 6 2004, 03:54 AM)
it really helps to see someone else go through this stuff first. How much of a PIA was it to get the motor in with the sheetmetal to seal interference?
I'm looking at your intake setup and mine is a little bit lower, so yeah! mine should fit without hitting!!
On the sheetmetal quexchtun,
The sheetmetal did just scrape the nuts on the trailing arms on both sides.Minor PITA but none-the-less it did need some massaging.
What did suprise me was that the top of the 915 case rubs the bottom of the rear trunk crossmember when I tried to tighten the support bolts.I make some spacers for the bolts today while I'm here at work.That should make some clearance.Maybe it's just poor quality on the Vellios case,I don't know,but not a big deal.
Ron
