Full Version: Headlight motors, one is balky....
Joe Bob
I had a good set for years....finally threw them away as no one wanted them and was tired tripping over the damn things.....so of course NOW I need one....I think....
The passenger side one refuses to go up without a tiny nudge/touch on the plastic knob on the rear of the motor....then it won't go the max height without a little more help from the knob.
Any ideas on fixing them? I tried the BFH tap trick on the motor housing like I use on the starter solenoids....no go....
Joe Bob
What? No one ever had this problem?
I just ordered some new H4s and would like to fix it or replace the motor when I do the install....
QUOTE(mikez @ Jul 6 2004, 01:14 PM)
i had. turned out it was the relay ...
try switching with the other side ...
Andy
Dave Bell
Mike -
If you need another headlight motor, let me know, I probably have a few lying around.
I can either just give it to you or trade straight across for that V8 914 you are trying to unload.
- Dave
Joe Bob
I;ll try Andy's suggestion and if that don't work I'll hit ya up....thanks.
Eric_Shea
I've got a pair as well if the relay doesn't work.
