QUOTE(pcar916 @ Aug 15 2011, 07:27 AM)
I put mine in after a two year storage although it had fewer miles than this one. The injectors were clogged but everything else was fine and there were no leaks. Make sure you're getting the DME and DME harness with it.
1. Check to see if the engine is one that has an engine wiring-harness recall. The insulation on those disintegrates. New ones are very expensive but the recall harness (same part) is many hundreds cheaper. The recall is tied to the VIN, not the engine SN so you'll need that. You don't want a $700 (est) part to make the engine more expensive than you thought.
2. Install new lower valve cover gaskets. Just do it when the motor is out, you'll be very glad later.
3. Get the injectors serviced... if it's stored for that long. ~20 each.
Leakdowns and comp test on a stored engine may not that reliable, but with 90K it's just barely be broken in! You'll want to take the valve covers off to check the valves for side-play. It's a known issue with this motor that the exhaust valve guides are subject to wear.
... wonderful engine for our 914's.
Good luck
Ditto the same for my engine on all accounts.
My 993 3.6 I bought back in 2000 from an add placed thru a PCA club website.
Me and the seller negotiated the price down, eventually buying it with the stipulation it would be a "core" engine. I got mine fully complete w/all wiring & ECU for 4k. Remember, if you're getting a good deal, you most likely won't see any kind of response if you spend the time and $$$ putting everything together and something is wrong with the engine. You'll be on your own. If you go in thinking that way anyway, you won't be shocked with any surprises as you move forward.
My motor sat in a climate controlled environment for 5yrs before I was ready to use it.
When I did get it going, it leaked from what seamed like every seam, and 2 months down the road it started knocking.
I removed the engine, tore it down and did a full rebuild. It had had a spun rod bearing when I got it. So I took it in stride, and did my own full rebuild.
Shameless plug. You can see my blog for where I let my grand daughter put the engine back together.
During the rebuild, my engine was as typical. Valve guides were shot. The main engine wiring harness was toast also. All issues were address. The rebuild including new exhaust was about 9k. So now, with 13k into the engine, I know exactly what I have going on behind me as I motor down the road.
Do the following before committing to a transaction price.
1. look into the exhaust ports. If it looks blackened, and oily wet, then the guides are gone, and will need replacing. Valve job at a minimum.
2. Check the Main Engine Wiring harness. Easiest place to check is the fuel injector connectors, and the engine grounding point. If you can see bare wire on the end of the injector plugs, or around the brown wiring on the grounding point, the harness has not been replaced, and will need to be replaced ASAP. Failure to do this turns all your efforts into a fire hazard.
these 2 things alone should give you an idea what you'll be up against as you get into a 3.6l.
Lastly, the injectors will need to go out for service. They'll mostly likely clog from sitting, and will set off a fault code when you start it up. I sent mine off through RockAuto for about 25.00 a piece.
Good Luck,
Ron
