Ian Stott
Aug 15 2011, 03:38 PM
I have a 73 2.0 4, all original except for fatter tires and an updated stereo, need a new injector, will a 75-76 injector work?
Ian Stott
Moncton
Canada
914werke
Aug 15 2011, 03:41 PM
Yes
Ian Stott
Aug 15 2011, 03:52 PM
What is the difference? I noticed in my confirmation e-mail from AA that I was getting the 75-76 injector, I thought maybe I ordered it wrong, if it doesn't matter then I will just use it as I am not driving the car right now because of the leaking injector. We only have so much summer where I live and I hate to lose the warm days!
Ian Stott
Moncton
Canada
Drums66
Aug 15 2011, 03:55 PM
SLITS
Aug 15 2011, 04:00 PM
The difference would be in the flow rate in lbs/hr, cc/min, etc
'75 - '76 Bosch Injector was/is a 0 280 150 038 - 400cc @ 3 bar
'73 - '74 Bosch Injector was/is a 0 280 150 019 - 406cc @ 3 bar
'75 - '76 914 had a smog pump & catalytic converter and were made to run leaner than the earlier ones.
Oops, found some info & noted above. I feel better now!
Ian Stott
Aug 15 2011, 04:01 PM
QUOTE(Drums66 @ Aug 15 2011, 06:55 PM)
Mine are green and the pictures in the AA website show them as green, but the 75-76 one has an A at the end of the part number.
Ian
Ian Stott
Aug 15 2011, 04:19 PM
Better send it back and the get the one for a 73, any difference between new and rebuilt other than the price?
Ian
Drums66
Aug 15 2011, 04:48 PM
QUOTE(Ian Stott @ Aug 15 2011, 03:19 PM)
Ian
.....But yes......have them all the same
(flow rate etc-etc-etc)
SLITS
Aug 15 2011, 05:38 PM
019 Injector carries a part number of 039 906 031 (Porsche/VW '72 - '75)
038 Injector carries a part number of 039 906 031 A
The flow figures I quoted are from a rebuilder. Testing them at 3 bar (44.1 psig) is a bit stiff as the sustem runs at 28 - 30 psig. So the flow rate will be less by 33% at the least, giving a flow at system pressure of 268 for the 038 and 272 for the 019.
jim_hoyland
Aug 15 2011, 06:22 PM
What's the flow rate for a 76 912E injector ? I've been told that my 75 L-Jet which has a 2L crank 96mm pistons might run stronger with the 912E injector. Does this sound right ?
sixerdon
Aug 15 2011, 07:26 PM
QUOTE(SLITS @ Aug 15 2011, 02:00 PM)
So, those with a '75/'76 2.0 who have removed the smog pump and back dated the exhaust system to '73/'74 specs, should use the 019? (except for the CA guys with '76's)
Don
914werke
Aug 15 2011, 08:01 PM
We are talking about a 1.5% difference in flow as rated for a NEW injector.
again, Yes it'll work
SLITS
Aug 15 2011, 09:24 PM
QUOTE(jim_hoyland @ Aug 15 2011, 05:22 PM)
According to the chart, they are 188 cc @ 3 bar. 0 280 150 105 as I remember. Looks really lean to me in comparison.
Dave_Darling
Aug 15 2011, 11:32 PM
QUOTE(SLITS @ Aug 15 2011, 08:24 PM)
I believe that L-jet squirts each injector twice during a full camshaft revolution, instead of just once like D-jet does.
--DD
Valy
Aug 16 2011, 12:09 AM
QUOTE(SLITS @ Aug 15 2011, 03:00 PM)
The numbers quoted are probably from WitchHunter.
BOSH claims that both injectors quoted above
have the same flow rate.
See attached original specification.
Click to view attachmentSLITS, whatever you're smoking, you better give me some too!
SLITS
Aug 16 2011, 07:30 AM
Numbers are from WitchHunter & I know the machine they are derived from. Glad you found a chart ... been looking for a long time for kicks as I just use the correct injector for the application. Never looked for "free" power boost as I figure the engineers probably knew what they were doing.
Not smoking or drinking anything ... gave it up again as a lost cause.
Ian Stott
Aug 16 2011, 03:58 PM
Ordered the correct injector, I hope AA doesn't get too upset with me for ordering the wrong one, the only difference was an A at the end of the part number for the 75/76, still my mistake though!
Ian Stott
Moncton
Canada
Drums66
Aug 16 2011, 04:39 PM
QUOTE(Ian Stott @ Aug 16 2011, 02:58 PM)
Ian Stott
Moncton
Canada
...George should know better!
