Yes, coil-overs would be nice... but we're talking over $700 for a set, as opposed to $100 for a decent set of springs.
I will look into a performance set of shocks though. Never really researched that. No one ever told me I needed to do it, and I figured with only 27K miles, it wouldn't need them.
Remember, you get what you pay for! Unless these are reputable springs and you are getting an unbelieveable deal... Seriously, save up for a complete package, it's worth it in the end.
The factory shocks are matched to the factory springs and it DOES make a difference when you start swapping things around.
The mudflaps may or may not cause you issues. I think the VW ones I had were longer. Just wait and see.
Yes, I went with an appropriately sized tire on the car. The total height of the wheel/tire combo is the exact same as stock. The tires are a 225/40 ZR18, Kumho Ecsta tires. They work quite well I think.
I have the same tires, love 'em. Especially in the Oregon wet <_<
After I lower it, I'm looking into a short-ram intake, and a high-flow cat back exhaust. After that, a good tint job. After that, MAYBE a JDM Type-R front lip spoiler.
Upgrading the intake/exhaust system will help. Remember, it's only as good as the smallest opening. The 4-2-1 exhaust header is a good suggestion (I'm getting a ceramic-coated one installed next week on my Jetta) along with the [larger diameter] cat-back exhaust. I went with a stainless steel MagnaFlow and it
rocks! VW cats flow really well so mine doesn't need replacing to a performance unit. If I went forced induction then maybe so.
As to the suggestions about engine mod performance, if you don't want to dump a lot of money and time into the engine (forced induction) then after the intake/exhaust put in some lumpier cams (I got those going into my Jetta as well in a couple weeks)
Oh, above all, the first engine mod should be an after-market chip (ECU upgrade). I don't know diddly about Asian cars but for VW's (and Audi') you can get CARB-approved chips to bump up performance...and you will notice the difference! My Jetta came to life (Neuspeed P-Chip for ODB-I, C.A.R.B.) as did my girlfriend's 1.8T Passat (with Tiptronic chip
) -- WOW! what a difference
Oh, and as I tell all of the dubbers on the
VW Vortex, use nothing but
pure synthetic oil for the engine and tranny (see owner's manual for the proper weight range for your climate). You will increase drive-train life, reduce friction, get a slight increase in gas mileage (as much as 3mpg) and horse-power (I gained 5hp in my Jetta). You can double to triple the oil change intervals because synthetic oil doesn't break down like conventional so it lasts longer -- for turbo'd cars, using synthetic is a no-brainer.
More here!QUOTE
After that, I'm done. Anything else I think would be tasteless, and actually detract from the car
Riiiiight...that's what we all say
