Ok, time to get some opinions here: My 74 2.0L had a contact plate with a broken ground wire on the contact plate; SLITS was kind enough to send me a new contact
plate with intact wire. Upon putting it in, not only did I notice that my dizzy now is
quite a bit more rotated CCW than it used to be, I can't get the car to idle well and it
will only run if I have the vacuum retard line to the dizzy disconnected. If it is idling at 1000rpm, upon connection of that hose, the revs drop significantly enough to make the car try to die. I have no ability to adjust idle using the air bleed screw on the throttle body either. It's like there is a big vacuum leak somewhere....
I'm not too well versed on the EFI stuff yet but have been spending lots of time looking at Anders website. I have unplugged Temp sensor I and it's idling better without it but I still can't hook up the retard vacuum line or adjust idle screw. I did notice that the AAR is a little loose on top where the hoses fit on; could it be leaking at the top?
The only things I have done prior to the distributer plate install was I removed the air cleaner and had a look around underneath. I don't think I messed up anything upon reinstall; it's pretty simple. My vacuum hoses are all pretty much new; oh, I did replace the hose that goes from the AAR to the cold start valve while I had the air cleaner off. Could I have disturbed the AAR enough to cause this problem? Everything was pretty good with the car prior to doing the dizzy and the only reason I wanted to change the plate was because my ground was broken and I wanted to fix it instead of how it was rigged. I had it wedged underneath my Pertronix module plate. It worked but I'm not nuts about rigging stuff...
Any ideas of where to start before I start testing components? I'm still thinking about the AAR being the culprit...anyone have any leads for me?
