QUOTE(Valy @ Aug 16 2011, 04:02 PM)
QUOTE(kg6dxn @ Aug 16 2011, 01:24 PM)
It is a cheap POS but, I have used one before with moderate resutls. Buy an Aeromotive regulator if you want it trouble free.
Mike,
POS means it will not hold constant pressure or that the pressure is not correct or leaks?
I just need it to run about 35 PSI.
You should be able to use it to hold 35psi. Taks all the fittings out and use teflon tape on them. In fact replace all the fittings with brass ones from home depot. Mount it on your return line before it goes back to the tank. Mount a seporate gauge on the supply line to monitor actual rail supply pressure. You will need to fab a mounting bracket for it. Do not let it bounce around. The pipe threads are a Chinese interpretation on NPT threads. Use lots of tape and put it on so it tightens the tape as you tighten the fitting.
