Full Version: CV Bolts & Bolt tool?
jandro62
Ok, so when I went to drop the transmission, the cv bolts looked pretty chewed. Where can I get a fresh set of these? What size are they? Also, I've seen references to a special tool for removing them? Are they just a little different than a torx bit? Pelican Parts lists bolts & tool for a 68+ 911, is this what I want?
TimT
its a double square bit, 8 points. Torx are 6 i believe, the 911 tool listed in PP is the one...
This same bit is available at your local sears, or good auto parts store
Joe Ricard
Got to have a good "tool" to work on 914's
davep
I thought it was a tri-square, but I could be wrong. Anyway, you need to use new bolts and new lockwashers. Torque them up properly and don't forget to check after a week of driving. There are many stories of grief when they get loose and the drive shaft acts like a big club and whacks everything within reach. On a friends car it just bent the gearshift rod, but others have had serious damage.
SLITS
How bout a 12 point Star bit or just ask for the VW CV Bolt tool.
You can replace them with a hex head - just match strength, length and thread.
or something like that
TimT
I was just thinking it might be a tri-square also.... actually I think it is tr-square... Im going to pull a bolt outof my scrap stuff and check
had a shitty day at work and am tired,
In any event you can get the tool locally... sears, or a good auto parts store.. or hardware store..
TimT
tri square is correctamundo Dave...
here are some selected bits for internally driven bolts..
TimT
Snoooozle
Malmz
My Sears no longer has them (I checked recently).
Pep Boys did:
All the info you need should be in this picture. Less them $10 for the set if I remember correctly:
From my experience, always tap them lightly with a hammer to fully seat them though the muck and grit before torqing on them.
Kerrys914
Malmz
No affiliation or experience:
http://www.thetoolwarehouse.net/shop/LIS-60750.html
EDIT: But they have a $50. minimum order.
Here is another one w/o a minimum for $13.49:
http://tools-plus.woodmall.com/lis60750.html
Or if you just want the 8mm you need, $6.39
http://tools-plus.woodmall.com/k-d2304.html
sm
MarkV
It's nice to have one that goes on a 3/8" ratchet without the use of a separate socket.
Here is one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
TimT
It wouldnt surprise me a bit if Pelican takes "liberties" with the pricing of these tools
Lisle is the brand I just couldnt remember...
KB is another brand that makes these tools
Heck order one from snap on!! you can do that online now!
Kerrys914
Mine is in the mail as we type. Couldn't find one at any of the FLAPS.
