QUOTE(larss @ Aug 17 2011, 01:34 AM)
QUOTE(SirAndy @ Aug 17 2011, 07:29 AM)
They came from the factory with drain holes that have small plastic plugs in them.
Thanks, that makes sense! My left hell hole has that plug and hole and my right has not, the right side has been re-welded by PO and they must have "forgotten" to make a new one...
/Lars S
The factory drain hole still leaves about 1/2 inch of water in the bottom of that area.
I typically drill a hole at the lowest point of the engine shelf, not the long and let it run out on the inside.
I added a piece of tubing to my car so it does not soak the heater tube and fuel pump which are right below the hole.
You can get a drill in from below or above with the motor in the car.
Ran the tube down below the car....let it drip out while driving.
I also clean that area yearly with a mixture of baking soda and water to stop the battery acid from doing its thing.
Rich
