jimkelly
Aug 17 2011, 08:44 AM
pic
jimkelly
Aug 17 2011, 09:11 AM
notes to myself...
** 3 pulled exhaust studs
** extract busted oil temp sensor
** fix oil leaks
Mike Bellis
Aug 17 2011, 09:13 AM
The relay in the 3rd pic looks like a hot start relay. You should be able to connect the FI wiring and a hot to the coil and ECU and it should start. You don't need the relay board.
r_towle
Aug 17 2011, 09:19 AM
QUOTE(kg6dxn @ Aug 17 2011, 11:13 AM)
you will then be running off pure battery with no alternator....keep that in mind.
Rich
jimkelly
Aug 17 2011, 09:29 AM
thanks guys
it is a 1973 GA 2.0 in a 1975 914
i fried a bunch of distributor wires and it ios easier for me to figure stuff out with engine out of car.
jimkelly
Aug 17 2011, 10:20 AM
damn cheesehead tin screws : (
about 1/2 are a bitch.
jim
TheCabinetmaker
Aug 17 2011, 10:34 AM
hand impact screwdriver will back those puppys out like butter. If you don't have one, you need one.
jimkelly
Aug 17 2011, 11:06 AM
thanks - don't have one YET - jim
QUOTE(vsg914 @ Aug 17 2011, 09:34 AM)
