I went into the hell hole today [w/out the engine in thar] and removed the rubber crappy pad on the firewall...no probelm rust! Just a little surface rust in on area but it can be cleaned and painted.
One thing about the design of the "hole" They have two "pockets" just forward of the engine mounts that collect a ton of dirt and the have no drainage. Anyone have a good location for drainage holes or is this OK to leave as is?
In respect to the pad. It's pretty worn out and ugly. Is it best to make one up out of the same foil faced material used under carpets as insulation or is there a really good pad on the market? Where can I get it?
Thanks you all!
Peter
74 2 Liter
