I'm bench testing two fuel pressure regulators (PN 0 280 160 200).
One unit regulates line pressure to 40psi while the other regulates to 39psi.
Both reduce line pressure to approx. 32psi at 0.5 bar. Here's my question,
The 40psi unit allows line pressure to bleed off almost immediately, while the other holds pressure at approx 35psi almost indefinitely. What gives? I thought line pressure was held by a check valve in the pump and has nothing to do with the regulator. My test setup shows otherwise.
Also does the 1psi (2.5%) line pressure really mean anything to performance?
Any thoughts?
