QUOTE(Cap'n Krusty @ Aug 29 2011, 05:33 PM)
All the 6 cylinder motors prior to the 964 share the same overall dimensions, and the covers must be machined to clear the body. You "could" use the 911SC lower cover, which looks a lot like the mag covers but it's aluminum.
The Cap'n
Aye Aye, Sir! Thanks for stopping off the freeway a few years back to deliver a rotor for the marelli.
Do the stock ones leak so badly they aren't used. I like original.
New question, if you don't mind. Where should the throttle cable be on top or bottom of the bell crank? I found it on top but the cable is too long when positioned there.
