QUOTE(SLITS @ Aug 23 2011, 08:55 AM)
One side of the momentary switch (starter button) is switched hot and the other side goes to the solenoid on the starter.
Hmmmmmmm The stock wiring has a M/F fitting for the normal key switch, the " Push button' starter has a loop/circle fitting. No way of fitting button wire to solenoid??? Hmmmmmmm would like to keep back up starter button if I could. Bob
