Mikey914
Aug 24 2011, 01:02 AM
Click to view attachmentJust thought I'd put a "how to" Thread together.
Yes Acrylic will scratch, the good news is it can be restored. In fact I'm even thinking about making a restore "kit" that would include smaller sizs of the compounds that I use, as they come in 48oz bottles.
Anyway, I started with a piece of rejected acrylic and made a "Test" pattern to sow you what was possible.
Mikey914
Aug 24 2011, 01:09 AM
I start by wetsanding with 1200 grit.
Mikey914
Aug 24 2011, 01:10 AM
Wipe clean and repeat with 2000 and 3000.
Mikey914
Aug 24 2011, 01:15 AM
Click to view attachmentStart by useing a mild cutting compound to reduce some of the fine scratches caused by sanding.
Mikey914
Aug 24 2011, 01:23 AM
Wipe clean and follow up with a machine polishing compound, and following up with a superfine polish.
For a total of 3 steps. You will need to switch to sponge pads for steps 2 and 3.
Mikey914
Aug 24 2011, 01:26 AM
Repaired test section
Mikey914
Aug 24 2011, 01:27 AM
Side view
Mikey914
Aug 24 2011, 01:28 AM
Decided I'd try to clean up my scratched Saratoga top
Before
Mikey914
Aug 24 2011, 01:32 AM
Wetsand with 1200, 2000, 3000
Mikey914
Aug 24 2011, 01:35 AM
I polished as I did before, unfortunately when you repair scratches you find more. You will notice that as you sand you can see the scratch until it's sanded out. You need to get these all the way out with 1200, before moving on to the next 2 steps
Mikey914
Aug 24 2011, 01:40 AM
You can really make these look good, I typically spend 2-1/2 hours on a roof prepping before I ship.
The one this to remember is as you polish you will build up a static charge. If you use a Meguires #1 plastic cleaner last, it will discharge the plastic so that every piece of dust that exists to your now clean top.
Drums66
Aug 24 2011, 04:49 PM
StratPlayer
Aug 24 2011, 04:51 PM
Amazing
Drums66
Aug 24 2011, 05:23 PM
