I just picked up a Gauge and taco plate with sender. Both are OEM Porsche 914.
Question is since my car did not have the temp Gauge (Parking brake flasher instead) is the wiring in the car from the factory to hook up the oil temp Gauge as it was an option?
I do not have the optional center console with the aux gages either, but I did see some extra wires in the tunnel with connectors not hooked up to anything. Also is there a wire for the sender in the engine compartment already there?
Should be pretty easy to do just one wire.
