1970 Neun vierzehn
Aug 28 2011, 06:55 PM
I am assuming this pad was used for heat suppression or sound deadening. Were the used throughout the series?
monkeyboy
Aug 28 2011, 10:39 PM
my late 72 has one.
eric9144
Aug 29 2011, 11:09 AM
The pad style changed in later model years, went to a full size pad that was the same dimension as the rear trunk carpet. I can add a picture tonight.
flipb
Aug 29 2011, 11:20 AM
My '74 has the full style trunk pad beneath the carpet. In places, I think it's still tacked into place with some kind of adhesive. It even covers the jack storage location, but it's flexible enough to pull upward to access the jack.
I don't spend much time in the O&H forum, so I should add: My car is a bit of a time capsule, but extensively driven. It's a 1974 2.0 in Saturn Yellow with brown interior. It's never been restored. AFAIK, everything is original except induction system (FI was long gone before I owned it) and heat exchangers/exhaust (some PO put on a Monza/Manta). It's been resprayed (low quality job) in the original color at some point, and some rust rehab was done in the hellhole and longs. Rocker covers are stock-style Stainless steel, powdercoated matte black.
Some of the factory markings (e.g. top of the strut towers in front trunk; steering wheel) are still visible.
Pat Garvey
Aug 29 2011, 06:50 PM
QUOTE(eric9144 @ Aug 29 2011, 11:09 AM)
Eric,
Was was the composition of the later pads? Believe they started in late '73.
Was it still a foam core wrapped in a vinyl sheath?
Pat
bembry
Aug 29 2011, 07:48 PM
QUOTE(Pat Garvey @ Aug 29 2011, 05:50 PM)
Eric,
Pat
Pat,
My 73 has the larger pad. Mine is not wrapped in a vinyl sheath (I've seen the vinyl wrapped ones for sale)--it's just black very heavy molded foam about an inch thick, that is smooth textured on top and bottom.
I think the purpose was just to hold water in order to rust out the rear part of the trunk.
sixerdon
Sep 2 2011, 08:28 PM
If everyone refers to their copy of Johnson's authenticity book, you will find your answer. They got it right on this one. Three different pads.
Don
eric9144
Oct 4 2011, 08:33 PM
Rear Trunk Pad 1974 MY (Prod 10/73) Pad is roughly the same dimensions as the carpet that covers it. Material is a dense foam with a smooth coating.
Van914
Oct 5 2011, 09:41 AM
If anyone is looking for on I have one for sale. It is like Eric's picture above.
Thanks
Van914
Kansas 914
Oct 5 2011, 06:28 PM
QUOTE(Van914 @ Oct 5 2011, 10:41 AM)
Thanks
Van914
PM sent....
914runnow
Oct 9 2011, 09:10 AM
they stopped in 72..73 started the ..'Molded' pad.....
windforfun
Jan 21 2012, 03:41 PM
QUOTE(eric9144 @ Oct 4 2011, 06:33 PM)
Click to view attachmentDitto.
dcheek
Jan 23 2012, 07:00 PM
Here is the pad from my '76. It's a very thin vinyl covering over soft and pliable foam approximately 1" thick.
unpolire
Mar 1 2012, 11:06 PM
My 10/71 1972 has the pad as pictured in the first post, as did my previous 1971. I agree with the comment that they just seemed to support moist conditions for rust directly beneath them, like a covered sponge.
